Std leak test before flow test
Anything flowbench related
Postby StevenFord » Wed Jun 24, 2015 9:59 am
Is everybody still doing the std pre head leak test before the actual flow test, like the Superflow manual says, or are you confident in skipping it like some people are claiming to do.
StevenFord
Re: Std leak test before flow test
Postby Chad Speier » Wed Jun 24, 2015 10:11 am
I usually skip it. I will turn the bench of without the valve run down and look at the manometer. If it's leaking, you will know.
Postby StevenFord » Wed Jun 24, 2015 4:05 pm
Chad Speier wrote:I will turn the bench of without the valve run down and look at the manometer. If it's leaking, you will know.
Can you explain that further.
StevenFord
Return to Flowbench Talk
