950 gas carb
Buy, Sell, Trade
950 gas carb
Postby jmarkaudio » Fri Oct 26, 2012 1:10 pm
I put this together to do some testing with, I have run out of time at the moment to mess with it. I'd rather give it a good home, and build another later when time permits. It's been started for idle circuit calibration and to make sure nothing obvious is wrong. I'll include jets above and below the starting calibration I have in it, unless an oxygenated fuel it will be close as is. It's a 1.45 venturi QF body with custom BLP machined .450 boosters, BLP billet metering blocks with my calibration, BLP 1.75 blade dual pattern billet base plate with nickel plated shafts, QF sight glass float bowls, BLP N&S, NASCAR vent tube... as well as a few other little improvements. All the best parts to provide any tuning changes needed and a carb to last a long time, a great bracket carb for a milder small block or real mild big block. $775 shipped to continental US only.
Re: 950 gas carb
Postby Adger Smith » Mon Nov 12, 2012 10:54 am
Call me when you get a chance.
Adger 903 824 4924 cell
Adger Smith
Return to Free Classified Talk
