NEW MEMBERS CAR PICS
Postby hb_350 » Wed Nov 04, 2009 12:28 am
nomad wrote:Saaaaay, is one of you guys James Lewin?
Nope, my name is Grant Petagna.
nomad wrote:So is that blue car above a Vauxhall or a Torana? What does it weigh? Neat cars BTW.
My junk.
http://www.guertinracing.com
Blue car is a HB Torana, same as the Vauxhall HB Viva with a couple of cosmetic changes made by GMH for the Australian market. Unsure of weight but the previous owner said it was around 2800lbs with a blown small block and him in it. Car has previously run 8.4's 160+mph over the quarter but I'm only looking for mid to high 9's. Nice car you got there as well Bruce, I wouldn't really call it junk though :lol: . Cheers, Grant.
hb_350
Postby Darin Morgan » Mon Nov 09, 2009 4:44 pm
I purchased a 2010 Camaro with the intention of making into a decent street strip car. I have worked on it and finally got it into a condition where I felt comfortable taking it to the track. The engine is stock. The mods are below. The first run with traction control on and going though some slight spin and wheel hop it ran a 12.81 (see ET slip). After that run I took the traction control off and put it into Sport Mode. The tune up has Torque management at about 30% on the 1-2 shift and 50% for the rest of the shifts. With the traction control off and in Sport Mode it ran a 12.66 ET at 110.88. It spun a little in first and shook a bit on the 1-2 and 2-3 shifts. With a set of Drag radials it will go 12.50 at 112mph with no problems at all. I wasted four other runs with spin and shake all the way through first and second even when I tried to pedal it. Trying to hook up on Street tires is a real Bitch.
L99 SS/RS
ARH long tubes 1 7/8, High flow CATs, loudmouth 2s, New Era CAI, 160 thermo, ported throttle body, Tune by Mike at New Era.
Video of run. Car # 39
http://www.youtube.com/watch?v=gCHFMmSlmzI
Image[/url]
Darin Morgan
Postby Jason G » Mon Nov 09, 2009 11:33 pm
Darin,
Very cool! Pretty darn quick/fast for a basically stock car.
Glad to see you out having a little fun!
Jason G.
Jason G
Postby Chad Speier » Tue Nov 10, 2009 8:14 am
Darin is a bracket racer, Darin is a bracket racer...
Fun wasn't it!
All I want to know is if Megan Fox came with the car? My gosh that woman is hot! Her name should really be Megan (I'm so hot I'd make you write bad checks) Fox.... Or one word like Madona.. FUEGO :D
Postby hb_350 » Tue Nov 10, 2009 4:57 pm
Chad Speier wrote:Darin is a bracket racer, Darin is a bracket racer...
Fun wasn't it!
Settle down Chad, don't get too excited now :lol: . I hope your missus doesn't read your forum :shock: . Nice car you got there Darin and some good numbers for whats been done. Cheers, Grant.
hb_350
Postby jmarkaudio » Tue Nov 10, 2009 6:30 pm
Just have to work on that RT a bit.... :lol: :lol:
Postby SB2NOVA » Wed Nov 25, 2009 12:15 am
Here's mine 72 Nova 465" SBC with SB2.2 heads, PG, 9", aerospace brakes, since then I've added another fogger, changed cams and slugs. Haven't had a chance to run the new combo still undecided on a few things. Thanks, Marty http://www.youtube.com/watch?v=mhKqSQhoy1w
SB2NOVA
Re: NEW MEMBERS CAR PICS
Postby masracingtd1167 » Thu Jan 05, 2012 2:55 pm
My Top Dragster
My Top Dragster
masracingtd1167
Postby Chevelle Rob » Thu Feb 14, 2013 11:36 pm
Well i finally got around to signing back up here after losing my other info to log in. Some of you may recognize my screen name fro Yellow Bullet. I own Devastation Motorsports doing photos, video and event coverage stuff and free lance for Dragzine.com
This is my Chevelle. It's a 468 with 049 heads, vic. Jr. 454 O intake I did. TH 400 Trans with a 12 bolt and 4.10 gear. Big Shot plate with Induction Solutions hardware with a small shot.
ET is 10.66 @ 125 NA 9.56 @ 138.99 on the bottle.
Best 1/8th is a 5.93 @ 113, 1.28 60' should go a low 9.4 with a similar 1/8th.
I also work part time in a local cylinder head shop doing some porting. Mostly basic nothing crazy stuff. I had enjoyed looking here for info before and will be looking and posting from time to time looking for random info and help to step up my work.
Thanks for the forum Chad.
Chevelle Rob
