Airwolf Results!!!
Postby trmnatr » Tue Mar 16, 2010 2:28 am
Cam you have, run 1.6/1.6 rockers
Install ICL at 107 advanced to 104
I dont like the springs. Could use much more cam
Use the 5.14's with the glide
Will give some more info later,,,
I would prefer a 105 but if you already have the cam it will work good, 105 lobe center would work better
cranecams.com
tricktrucks.com
Postby 358T » Tue Mar 16, 2010 8:16 am
trmnatr wrote:Bryce we have a few cams
cams we have tested with :lol:
1) super stock cam from a while ago before head porting, 256/262 @.050" (dont have cam card and not in computer, Would have to look at grind number tomorrow)
2) 307/317 @.020" 278/284 @.050" 201/197 @.200" .684"/.660" with 1.5's 106 lobe center
3) 292/300 @.020" 260/268 @.050" 180/187 @.200" .630"/.630" with 1.5's 110 lobe center
3) 307/313 @.020" 278/284 @.050" 198/204 @.200" .746"/.746" with 1.5's 106 lobe center (we have 2 of these on 4/7 swap)
4) 308/316 @.020" 278/284 @.050" 200/202 @.200" .670"/.630" with 1.5's 106 lobe center (we have two of these on 4/7 swaps)
5) Same cam above but on 4/7 & 2/3 firing order swap (we have 2 of these)
6) 308/314 @.020" 278/284 @.050" 200/206 @.200" .804"/.759" with 1.8/1.7's but will work with 1.4's 106 lobe center
Thats those, We have a bucket full of billet roller cams with all different durations from over the years. We have 2 Lunati's right now that are ours. 3 other cams that we are working with this spring brand new.
Too much $hit. Thats why I said your dad really needed a big cam :lol: :lol:
What engine were you testing these in? Look like you were playing around with exhaust duration and lobe area.
Scott
WWW.KillerRONS.COM
Tech and Sales
scottoffermann@inbox.com
358T
Postby trmnatr » Tue Mar 16, 2010 10:51 am
:lol: :lol:
cranecams.com
tricktrucks.com
Postby trmnatr » Fri Mar 19, 2010 11:53 pm
Bryce,
Here is the camshaft specs for you,,,
307/313 @.020"
278/284 @.050"
198/204 @.200"
.723"/.723" with 1.6 rockers 106 degree lobe seperation with 4 degree advance ground in
.020"/.022" Lash
Timing @.020" Tappet Lift (will start a little sooner as lash is .020"/.022" , With your 1.6 rockers will start ~.013" tappet lift) , this is with the cam 4 degree's advanced
IVO 51.5btdc IVC 75.5abdc
EVO 86.5bbdc EVC 46.5atdc
Timing @.050" Tappet Lift, this is with the cam 4 degree's advanced
IVO 37btdc IVC 61abdc
EVO 72bbdc EVC 32atdc
Here is the camshaft we will be running with your AirWolf 220 Heads (we have a few timing points this cam was checked at for certain reasons)
312/318 @.0175"
308/314 @.020"
278/284 @.050"
200/206 @.200"
.804"/759" with 1.8/1.7 rockers (It is designed for 1.5 to 1.8 but is .670"/.670" with 1.5's)
.012"/.012" lash
Timing @ .0175" 4 degree's advanced, We run this cam with ZERO advance
IVO 51.5btdc IVC 80.5abdc
EVO 86.5btdc EVC 51.5atdc
Timing @.020" 4 degree's advanced
IVO 50btdc IVC 78abdc
EVO 85bbdc EVC 49atdc
Timing @.050" 4 degree's advanced
IVO 36btdc IVC 62abdc
EVO 71bbdc EVC 33atdc
cranecams.com
tricktrucks.com
Postby trmnatr » Sat Jun 19, 2010 12:14 pm
Banjo any updates?
cranecams.com
tricktrucks.com
Postby banjo » Sat Jun 19, 2010 10:50 pm
It is running very consistant. I have been to the winners circle 4 times since putting on the heads. I still been tuning on it, I recently added an airpan, that pulls air from in front of the radiator. It has really picked up the car. Figure the airpan was good for a solid .08 and 1 mph in the 1/8. Tonight, it went a 6.62@104mph in 5200 foot of air on a marinal track. Previous heads, it would have been in the high 70s, low 80s. Still playing with it, I am going to try and give it some more timing tomorrow and see if it likes it. I just can't wait to get this thing in good air again because it is running very strong. Unfortunitly I probably wont see it for another 2-3 months. We will see what happens.
Bill Simpkins
smallblock 406 with the original Airwolf heads.
1/8 6.15@110mph (11/11)
1/4 9.87@131 (02/13) On the rev limiter.
Fourtenposi@yahoo.com
Re: Airwolf Results!!!
Postby banjo » Tue Nov 27, 2012 6:49 am
Well its been nearly two years and with the exception of a small bump in compression and chad updating the heads, motor is the same.
I am finally getting this combination really sorted out.
Here is a video of it this weekend, I was having issues keeping the nose down. Best was a 6.19@110, a little off from my best run yet, but I think there is a little bit more in the chassis. Car was sixty footing in the 1.33 range with a handful of 1.44-1.46 range.
http://flic.kr/p/dwzk8E
Thanks Chad for a great product and awesome customer service after the sale.
Bill Simpkins
Postby Chad Speier » Fri Feb 08, 2013 8:02 am
I hear banjo found the 9's!
Postby banjo » Sat Feb 09, 2013 5:33 pm
Yes Sir, I did, Tripping the sixty with the rear tires and on the rev limiter to the finish line. Motor pulled all the way to 7800 before the rev limiter.
Bill Simpkins
Postby John Wilson » Mon Feb 11, 2013 9:09 pm
Real Nice! 8) Congrats!
John Wilson
Postby banjo » Tue Feb 12, 2013 6:47 pm
Here is a video from the following day. Its a 6.30 pass, but still carrying the wheels out there pretty good.
http://flic.kr/p/dTvYE6
Bill Simpkins
Postby banjo » Sat Feb 16, 2013 8:09 pm
Bill Simpkins
