Slowly but surely
Postby Scott Smith » Sat Sep 25, 2010 11:33 am
The uncorrected power on the best pull was 795hp.
Damn Andy you had us all giddy on your original numbers.
You left out the fact that they were corrected! :roll:
Scott Smith
Postby Andy Hunt » Sat Sep 25, 2010 12:09 pm
Scott,
All dyno's have the raw data and data corrected to sea level conditions. What nobody ever tells you are the raw numbers.
Just like all flow bench numbers are corrected.
The airwolf dyno numbers in Dr. J's forum are corrected numbers.
And these are also corrected:
http://www.1320techtalk.com/viewtopic.p ... 71&start=0
Andy Hunt
Postby 358T » Sat Sep 25, 2010 12:20 pm
Scott, why is the uncorrected # so dissapointing?
I still think a 4.59 is possible if Andy gets to run in some good air at a track <500ft elevation.
Isn't the whole point of correcting dyno #'s is to have a standard measurement no matter the atmospheric conditions?
Scott
WWW.KillerRONS.COM
Tech and Sales
scottoffermann@inbox.com
358T
Postby jmarkaudio » Sat Sep 25, 2010 12:22 pm
Uncorrected numbers can be deceiving as well, my 461 made a little less uncorrected than the 447 and only 25 HP more corrected, however at only 50 lbs less the car was .25 faster. Same dyno, different time of year. Nice #'s on both Andy.
Postby jmarkaudio » Sat Sep 25, 2010 12:35 pm
4.60 and 7.30 range should be about right given the weight, when I take my runs in ET analyst and go to 1650 lbs. that is where it's at.
Postby 358T » Sat Sep 25, 2010 12:47 pm
I know of a 840hp (corrected 8) ) n/a 454 small block that has went 4.58 and 7.22 in a 1600lb dragster. It was also alky injected but with Brodix GB2300 heads ported by Rons Porting. This was at a track with 420 elevation and some really good fall air.
I know of another alky injected small block with 13* AllPro heads that has ran in the 7 teens n/a in the same conditions at the same weight. He claims it to be a 418. About 1.5 months ago I seen him run a 4.45 in the 1/8th with a small nitrous shot... Usually it is mid 4.5's
Both of these engines have a cam that is surprisingly different than what most on this board would call right.
Scott
WWW.KillerRONS.COM
Tech and Sales
358T
Postby 10.90streetcar » Sat Sep 25, 2010 7:41 pm
If that thing don't go 4.50's (in good air) something's wrong.
Nice job Andy.
FAST BY DESIGN
SBC
1.040
2.991
4.673 @ 143.32
10.90streetcar
Postby Andy Hunt » Sat Sep 25, 2010 9:35 pm
Once I get the converter ironed out, I'd like to make the trek to a track close to sea level. Our home track sits @ 975' above. The fastest I've been here with the other engine was 4.79, most of the time I was in the low .80's. I'm hoping to be a tenth quicker with this one.
Andy Hunt
Postby John Wilson » Sat Sep 25, 2010 10:45 pm
Those are damn fine results!! 8)
John Wilson
Postby Scott Smith » Sun Sep 26, 2010 7:36 pm
Andy Hunt wrote:Scott,
I know a few dyno operators that pull weather conditions out of thin air to make their engines look good for their customers.
So the 3000ft DA knocks out 76Hp?
On gas maybe but on Alcohol? I call BS. An alcohol motor only swings .10 from winter to summer while a gas engine swings .3
Get my point?
Scott Smith
Postby jmarkaudio » Sun Sep 26, 2010 9:04 pm
I still say the test will be in the car, but even the uncorrected #'s on the 447 was higher than my 461, yet the 461 is a lot faster. Even if the correction figures are on the high side, His torque figures look close to my 461, at 1650 it will have no issue getting the times I estimated or even a little better.
Postby Scott Smith » Sun Sep 26, 2010 9:21 pm
I'm not knocking the mans engine don't get me wrong. But when I saw almost 900hp I said wow and double wow!
Scott Smith
Postby RealOldsPower » Mon Sep 27, 2010 8:21 am
Get my point?
I see that you are dogging on the motor. Wait till it runs down the track if it flops then dog it. 3600ft DA will knock out 76 HP on a alcohol motor or gas for that matter. Have you dynoed your motor if so what did it make raw and corrected Id like to know.
Worlds Quickest Olds Powered Vehicle
RealOldsPower
Postby Scott Smith » Mon Sep 27, 2010 2:51 pm
No im not dogging the mans engine. I was just surprised at the corrected vs uncorrected difference.
and you say da will knock 76hp out of gas and alcohol. Then explain why a gas engine swings .3 and a meth motor swings .01
Scott Smith
Postby Andy Hunt » Mon Sep 27, 2010 4:00 pm
Here are the weather conditions taken from within the dyno cell. These conditions are recorded by the dyno in real time during the pull.
Andy Hunt
PreviousNext
Users browsing this forum: Bing [Bot] and 3 guests
