My home built tubing notcher
Postby Jim Johnson » Mon Jan 17, 2011 5:55 pm
LFE FLOW BENCH
STUSKA TRACKMASTER GOLD DYNO
EQUIPPED SHOP
304 425 4559
Jim Johnson
Postby mikeyfrombc » Sun Jan 30, 2011 1:37 pm
very nice job , do you happen to have a parts list for the items used in the build ??
mikeyfrombc
Postby Jim Johnson » Sun Jan 30, 2011 5:51 pm
The following parts were purchased from www.surpluscenter.com
Qty Part# Description
(2) 1-209-28-4 pillow block brg
(2) 1-3422m flexible coupling
(1) 1-3422x rubber insert for coup
(1) 11-2102 DC speed control
(1) 11-2102-r43 resistor for spd cont
(1) 11-2102-h heat sink for spd cont
I used a DC motor off of an old nc mill and bought a gear box off of ebay. You need a 5:1 ratio gear box if you are using a dc speed control if not you may want a 7:1 for lower rpm for larger diameter cutters. 1725 rpm motor with 5:1 will give you about 350 rpm cutter speed.
You could use 13-206-5-56c-de gear box and 10-2430 motor from surplus center if you can't find something cheap on ebay.
Arbor to hold 1.250 shank endmill cutter was made on lathe I can give you dimensions if you decide to build.
Bottom plate is 1/2 thick by 18 x 24 inches, has box tubing underneath for reinforcement, is not stiff enough without it.
Milling table is Shars brand, 4" swivel milling machine vise both bought local, about 190.00 for both. V vise jaw was made out of piece of 2X2 aluminum.
Arbor centerline from table was 9.937" with milling table and vise I used.
If you decide to build be happy to help with any other info.
LFE FLOW BENCH
EQUIPPED SHOP
304 425 4559
Jim Johnson
Postby mikeyfrombc » Sun Jan 30, 2011 10:35 pm
WHOA!!! :shock: 8)
COOL thank you so much for all the PN##s and the motor info i now have a new shop project that will come in very handy ,i have some R8 arbors left over from a old mill/drill i had yrs back , those will come in handy now after seeing your design .
thanx again
Mikey
mikeyfrombc
Re: My home built tubing notcher
Postby paul-dogs » Sun Dec 14, 2014 7:25 pm
been a while for this post but this looks good wonder if you could make me one like yours on a lathe. Arbor to hold 1.250 shank endmill cutter???
paul-dogs
Postby bubba2400 » Tue Jan 06, 2015 8:33 am
I am going to be using my lathe as my tubing notcher later this year hopefully. I am going to hold the 2" annular cutter in the three jaw chuck and then make a mount to hold the tubing in the carriage. This way I can use the power feed to evenly feed the tubing in to the cutter. Should help with cutter life.
bubba2400
Postby Foxchassis » Wed Jan 07, 2015 7:52 pm
Foxchassis
Postby bubba2400 » Thu Jan 08, 2015 10:35 am
That is exactly what I want to do. I have been notching in the vertical mill but it would be really nice to use the power feed of the lathe. I am going to try and work on that setup when I get some of the other projects out of the shop in the next month.
bubba2400
Users browsing this forum: Google [Bot] and 2 guests
