Manifold.
Manifold.
Postby gmhg70 » Tue Mar 08, 2011 8:17 pm
Just want to say thanks for the manifold.Eddy s/v with plenum and full port. Really top class work and service.
It's on a 383 sbc. Changed manifold , cam and comp .Went from a best 11.21@121 to 10.76@125. 1.54 in the 60.
Still tuning.
3400 pounds with driver. Street driven on pump gas.
Thanks Pep.
gmhg70
Re: Manifold.
Postby Chad Speier » Tue Mar 08, 2011 10:03 pm
gmhg70 wrote:Just want to say thanks for the manifold.Eddy s/v with plenum and full port. Really top class work and service.
Still tuning.
Thanks Pep.
EXCELLENT! Please keep us posted!
Postby 268M » Thu Mar 10, 2011 12:04 pm
Nice... Can you share the rest of your 3400lb car information? Gear, trans, heads, cam, compression ratio...
Mesik Motorsports - We don't drive round'n circles lookin' for the finish line
268M
Postby gmhg70 » Mon Mar 14, 2011 2:37 am
Some other info : heads are afr 210 eliminators ootb, comps at 11.7:1, cams a comp solid street roller 260/266 @ 50 589/598 lift with 1.5 rocker. But i've put a 1.6 rocker to give it a little more lift. Power glide with a UCC 8" 5000 converter, 4.3 gears and a Pro Syst 950 carb.
Pep.
gmhg70
Postby gmhg70 » Fri Apr 01, 2011 8:36 am
A little update. Ran car on VP MS 109 tonight.
New best 10.61 @ 126.99.
Pep.
gmhg70
Postby Chad Speier » Sat Apr 02, 2011 7:52 am
gmhg70 wrote:A little update. Ran car on VP MS 109 tonight.
Pep.
NICE!!!
Postby gmhg70 » Sat Apr 23, 2011 10:04 am
Ran the car tonight. Put a 50 series tyer on instead of a 60 series. Ran 10.58@127.xx on pump fuel. Put in VP MS 109 , 4 jets all round and another 2* timing ended up going 10.46@127.9 with a 1.49 60 foot .
Pep.
gmhg70
Postby RacerX » Thu Apr 28, 2011 10:08 pm
gmhg70 wrote:Ran the car tonight. Put a 50 series tyer on instead of a 60 series. Ran 10.58@127.xx on pump fuel. Put in VP MS 109 , 4 jets all round and another 2* timing ended up going 10.46@127.9 with a 1.49 60 foot .
Pep.
Congrats!! How does that plenum mod effect the throttle response with that pump gas?
Racer X
RacerX
Postby gmhg70 » Fri May 06, 2011 7:37 am
Throttle response Is really good.Just stab it and go.
I'm really pleased with the results I've had with this engine.
Thanks Chad for an awesome manifold.
Pep
gmhg70
Postby gmhg70 » Mon May 23, 2011 10:16 pm
another update :
put 4.56 gears in the rear , 60 series tyre 28" back on.
New p/b 10.44 @ 129.07 ! The pass before this one ran 10.45 @ 129.8 I also got told to fit a cage or don't come back :roll:
Pep
gmhg70
Postby gmhg70 » Wed Jun 29, 2011 5:37 am
Chad , a quick question.
I'm making the switch to e85. And wondering if the epoxy used in the manifold will be OK ?
Thanks Pep.
gmhg70
Re: Manifold.
Postby gmhg70 » Fri Aug 26, 2011 4:23 am
Made the swap to e85. Bought a 950 carb from Eric at Horsepower Innovations .
Excellent carb and service !
Put the car on the chassis dyno and picked up 15 kw at the wheels ! Not bad for a fuel change.
Was gonna race it but dropped a lifter and took out the cam as well .
So round three of this engine begins . Swapped head gasket to bring comp up to 12.85:1 , new Morel ultra
pro lifters ,pac 1225 valve springs to go with the new Bullet speced cam . 267 275 @ 50 , 675 630 lift 109 lsa 106 icl.
Waiting on cam to arrive and then back on the dyno .
Got a four point cage on ebay and a autometer wideband afr gauge , to help with tuning e85.
What you think ?
Pep
gmhg70
Re: Manifold.
Postby xe5800 » Sat Aug 27, 2011 3:54 am
Oh thats sucks about the lifter bud.
But atleast you get to upgrade, thats always a good thing.
So0000 we thinkin high 9s with the new combo. That would be gold hey.
Hope my car responds to changes like yours did.
Good luck with the new combo :D
xe5800
Re: Manifold.
Postby Orr89rocz » Sat Aug 27, 2011 11:56 am
Thats a heck of a power gain at the 10 second range. Nice work! Ported manifold really shows potential in a combo!
Orr89rocz
Re: Manifold.
Postby gmhg70 » Sun Aug 28, 2011 3:34 am
xe5800 wrote:Oh thats sucks about the lifter bud.
Up grades are always good ! :twisted:
Will be interesting to see where this round of mods gets me !
Have to wait and see . I'll fill you in . :wink:
Pep
gmhg70
Next
Users browsing this forum: Bing [Bot], Yahoo [Bot] and 1 guest
