lapping valves to check seating
Postby Uncrated » Fri May 25, 2012 7:26 pm
do you lap the final valve job, or, for a double check of seating is doing so acceptable?
Larry Woodfin
Flyin with Iron Wing
Uncrated
Re: lapping valves to check seating
Postby Chad Speier » Wed May 30, 2012 8:01 am
I just do it so the customer can see the lap line. Sometimes just on one cylinder.
Postby Chevelle Rob » Sun Feb 17, 2013 12:22 pm
Chad Speier wrote:I just do it so the customer can see the lap line. Sometimes just on one cylinder.
Chad do you vacuum test the seat work ?
Chevelle Rob
Postby SStrokerAce » Fri Mar 01, 2013 10:00 pm
I lap everything when I put a head together.... number the valves to their holes and lap them in with 500 grit.
Users browsing this forum: Bing [Bot], Yahoo [Bot] and 1 guest
