SB2.2 time frame?
SB2.2 time frame?
Postby jeff klei » Sun Jan 06, 2013 8:32 am
Chad, when are you going to start working on a sb2.2 program? Just curious as the 13 degree head was pretty dam good. Thanks, Jeff klei.
jeff klei
Re: SB2.2 time frame?
Postby jmarkaudio » Sun Jan 06, 2013 9:18 am
Did anyone get by the MBE booth at the PRI? They had an interesting drag port for the SB2, raised about 1/4" and an interesting intake opening shape. Almost like an egg, oval but smaller at the top going wider towards the bottom. Flow was supposed to be in the 450 range...
Users browsing this forum: Bing [Bot] and 3 guests
