sbc heads and flow.
sbc heads and flow.
Postby mcdonnough bros » Thu Feb 28, 2013 10:23 pm
Ok. at what point will head flow not be your friend. I see some of the heads advertised to flow 420@.900 and then some of the sb2.2 claim 450 @???? With say 434 inches when would the intake flow numbers actually hurt the performance I guess my question is how much flow does a sbc need/use is a 434-440 inches ? Is this something that is based on say rpm or horsepower goals. Thanks just gatherin info for personal reasons.
mcdonnough bros
Re: sbc heads and flow.
Postby Chad Speier » Thu Feb 28, 2013 10:40 pm
mcdonnough bros wrote:Ok. at what point will head flow not be your friend. I see some of the heads advertised to flow 420@.900 and then some of the sb2.2 claim 450 @???? With say 434 inches when would the intake flow numbers actually hurt the performance I guess my question is how much flow does a sbc need/use is a 434-440 inches ? Is this something that is based on say rpm or horsepower goals. Thanks just gatherin info for personal reasons.
Every engine has a cfm demand. Too much cfm and that means the head is too big for the combo. I will post the formula tomorrow.
Postby jmarkaudio » Thu Feb 28, 2013 10:43 pm
below
Postby jmarkaudio » Thu Feb 28, 2013 10:52 pm
On a 4" stroke plan to turn the SB2's 7000-8500. They will still work lower, just wouldn't be ideal. However, also look at the fact that the winning Engine masters engine was a 406 with SB2 heads and had to pull very low, the right cam can make a difference. I think they started around 4000 RPM, and the engine had a billet carb with a 2.400 throttle blade... :shock:
Postby upsidedown » Wed Mar 20, 2013 1:00 am
Chad Speir wrote:Every engine has a cfm demand. Too much cfm and that means the head is too big for the combo. I will post the formula tomorrow.
Hi Chad any chance of posting the formula. Thanks
upsidedown
Postby Chad Speier » Wed Mar 20, 2013 7:12 am
CFM demand = cid x rpm x .0009785 / # of cylinders
Postby upsidedown » Thu Mar 21, 2013 10:55 pm
Chad Speier wrote:CFM demand = cid x rpm x .0009785 / # of cylinders
Thanks Chad so using that formula for a 350 @ 7000 rpm gives 300 cfm. I assume that this is what you would need from your head / manifold @ 28" at max flow?
I expect at that size for cfm it also gives the correct velocity?
upsidedown
Postby JZEDBB6 » Mon Dec 12, 2016 5:43 pm
How do you then relate this formula to a boosted application :?:
JZEDBB6
Postby Chad Speier » Mon Dec 12, 2016 5:52 pm
JZEDBB6 wrote:How do you then relate this formula to a boosted application :?:
It sure seems a boosted application likes a little bigger port. Exactly how much is trial and error I would assume. I had a customer build a 400" X275 car with a port that's 370cc. It hauls!
