Chad, head question
Chad, head question
Postby jmarkaudio » Sun Dec 15, 2013 7:10 pm
My brother has a 421 with Pontiac 867 heads. The heads are raised runner with 2.10/1.60, standard valve location, standard exhaust ports, and uses non offset stud rockers. Is there an inexpensive replacement casting available he could use? He would prefer to use the raised runner Bowtie intake if possible. If not, what are the largest port import castings available? The heads are old, have a bunch of epoxy, and the plan is to run E85 so epoxy is out.
Re: Chad, head question
Postby Chad Speier » Tue Dec 24, 2013 9:40 am
I haven't found one.
I did trade for a set of smaller Edelbrock RR castings with a 2.150 valve.
Need a little repair work, but will be priced right!
Users browsing this forum: Bing [Bot] and 2 guests
