Dart Little Chief heads
Postby 1997bird » Mon Dec 08, 2014 12:50 am
Chad I was wondering if you had played with the Dart Little Chief #14700001 for a 4.5" bore spacing? The application would be for a 427 cid (4.190" bore x 3.875" stroke) application that would be on pump gas and have a peak HP goal of 8200 rpm. The engine will have a sheet metal EFI intake manifold with a forward facing TB if that is info that you need to know.
Shane-VP
Precision System's LLC
1997bird
