Dean Anderson's 434 DYNO w/v2.50
Postby Chad Speier » Tue Oct 02, 2012 7:16 am
434 w/v2.50 Pro-Filer Heads
Dart Little M
4" Crower Crankshaft
Oliver 6" Rods
Clevite H Bearings
Low Tension Rings
Ross 13-1 Pistons
GZ Vacuum Pump
Lunati 50125 Cam (271-281- .645/.645 lift)
SRH Edelbrock 2925 Plenum Mod Manifold
950 HP E-85 by Sullens
1" 4-Hole Spacer
MSD Pro Billet Dist 36º Timing
1 7/8 Headers
Dyno'd on a Stuska
Re: Dean Anderson's 434 DYNO w/v2.50
Postby Chad Speier » Wed Oct 03, 2012 10:02 am
This engine is doing a killer job of accessing all of the available head flow!
Postby comp262 » Sun Jan 12, 2014 5:01 pm
Chad, why do you think this engine is making way more and I do mean way more, ft lbs than pipemax says it should?
comp262
