Port Floor Shape
Cylinder Head and Manifold Discussion
Port Floor Shape
Postby bubba2400 » Fri Jan 23, 2015 8:37 am
How about a little discussion about an intake ports floor shape. Chad, I see you use a wing in some ports and a decent amount of floor bias to one side in others. Is this to try and direct the air around to the sides of the valve and away from the SSR?
I would assume with air being a "liquid" that it will take the path of least resistance and that with a smaller area in one part of the port will the air then change direction easier and go to the parts of the port that have more area?
bubba2400
Re: Port Floor Shape
Postby ou812 » Sun Jan 25, 2015 9:38 pm
From my experience...the vane helps keep the air stuck to the floor in some ports. I've used it in sb ford heads with success. Can't wait to hear what Chad has to say about it...
Brian
BRIAN HAFLIGER
IMM ENGINES
ou812
Return to Induction Talk
Users browsing this forum: No registered users and 2 guests
cron
