My K-Motion experiment
Postby Chad Speier » Tue Dec 27, 2016 5:16 pm
My K-Motion spring experiment!!
3 years ago I did a set of BBC cylinder heads for a 545 bracket style engine. We used a set of K1000H's. The plan was to look at the springs after a season. He sent the heads back and I checked everything out. I get the heads back after 400 passes yesterday.
Here is the AVERAGE of all 16 springs! 250@2.000/815@1.200 after 3 years and 400 passes! THE KEY IS IN RETAINER CLEARANCE! .835 lift with .085 to bind. 7800 RPM through lights
Re: My K-Motion experiment
Postby cgarb » Tue Dec 27, 2016 7:51 pm
Are the springs going to be reused?
cgarb
Postby Chad Speier » Tue Dec 27, 2016 7:55 pm
cgarb wrote:Are the springs going to be reused?
No we retired them. His choice.
Postby cgarb » Tue Dec 27, 2016 8:02 pm
Thats a good set of springs. I bet they have a lot more life in them. If at 1 year 1 spring was weak he probably would have replaced the whole set, 15 good springs retired by 1 bad one. He could put a new set on for this year and have a bad one in there...sort of the risks we take sometimes.
cgarb
Postby Chad Speier » Tue Dec 27, 2016 8:07 pm
cgarb wrote:Thats a good set of springs. I bet they have a lot more life in them. If at 1 year 1 spring was weak he probably would have replaced the whole set, 15 good springs retired by 1 bad one. He could put a new set on for this year and have a bad one in there...sort of the risks we take sometimes.
I agree. He just felt for $275 he wanted the piece of mind.
Postby Foxchassis » Sat Dec 31, 2016 10:31 am
Hi Chad
No one asked so I will, do you fit the spring to the retainer snug or allow some clearance?
thanks
Foxchassis
Postby Chad Speier » Sat Dec 31, 2016 10:40 am
Hi Chad
thanks
Clearance!!! Like when you turn the spring upside down the retainer falls off.
Postby Foxchassis » Sat Dec 31, 2016 2:56 pm
Clearance!!!
Thanks Chad
Foxchassis
Postby Chad Speier » Sat Dec 31, 2016 3:14 pm
I try to use the K-Motion titanium retainer when I use their spring.
Postby Chad Speier » Sat Dec 31, 2016 3:16 pm
PS, I'm WD with them and if you ever want to try or need something, I will treat you right.
http://www.speierracingheads.com/upload ... ochure.pdf
Postby RacerX » Sat Dec 31, 2016 3:40 pm
Chad, what is your thoughts on their newer M500 springs? I like the 1.500 diameter...
Thanks
RacerX
Postby ou812 » Sun Jan 01, 2017 2:19 pm
Hey Chad, do you use locaters more or cups? I tend to use cups whenever I can, but I've always wondered if cups actually help the spring work better than locaters...just curious. Happy New Year!
Brian
BRIAN HAFLIGER
IMM ENGINES
ou812
Postby Chad Speier » Tue Jan 03, 2017 9:53 pm
ou812 wrote:Hey Chad, do you use locaters more or cups? I tend to use cups whenever I can, but I've always wondered if cups actually help the spring work better than locaters...just curious. Happy New Year!
Brian
I'll use a locator if it fits like the retainer, loose. If not, I'll use a cup.
Postby BOZ-RACE ENGINES » Fri Mar 10, 2017 12:12 pm
Wow that is interesting, cheers, ive fitted most of my springs a little loose i rarely have spring issues, been told many times its wrong haha
BOZ-RACE ENGINES
