Flo-Tek Heads
Flo-Tek Heads
Postby Chad Speier » Sat Jan 07, 2017 6:32 pm
Anyone messed with or used a Flo-Tek cylinder head?
https://www.flootek.com
Re: Flo-Tek Heads
Postby Foxchassis » Mon Jan 09, 2017 6:10 pm
Hi Chad
I have a set of SBC Flo-Tek heads in the shop now to be repaired. Valves are sticking in guides. Honed a couple guides out a month ago,
he did not want to go thru the set. He put it back together and stuck a couple more. He says he has always had oil to top of motor??
May not have been oiled when assembled ??? Will let you know anything else. Are they oversees heads that are assembled in Indiana?? :roll:
Dwight Fox
Foxchassis
Re: Flo-Tek Heads
Postby Chad Speier » Thu Jan 12, 2017 4:06 pm
Foxchassis wrote:Hi Chad
Dwight Fox
I received a BBC. It appears to be the old Patriot Freedom. Not bad, needs seats.
Re: Flo-Tek Heads
Postby Foxchassis » Sat Jan 14, 2017 9:06 am
[needs seats.*]
Looks like the SBC heads need seats also, top cut is sort of flat( maybe 15 deg) .Seat ring is 2.100", STRHT is approx. 1.240". Maybe
could do a 2.080" valve with whats there, just would have a little valve drop. The ones I have are marked 200 w/2.025" valve.
Dwight
Foxchassis
Re: Flo-Tek Heads
Postby Chad Speier » Sat Jan 14, 2017 12:29 pm
Re: Flo-Tek Heads
Postby Chad Speier » Mon Feb 06, 2017 9:23 pm
Re: Flo-Tek Heads
Postby cgarb » Mon Feb 27, 2017 8:46 pm
The 220cnc sbc heads, who is doing the cnc work on them and are they your flow numbers? That seems like a decent flowing head for the money.
cgarb
