flow testing
Anything flowbench related
flow testing
Postby comp262 » Mon Jan 02, 2017 10:49 pm
Hi Chad,
I have a problem port I would like your opinion on. I have an area of the flow curve that goes a little turbulent on an intake around .550 lift, it does not loose much flow but then continues to gain right up to 1.00 lift.
I have flowed it at 10", 28" and 40" and it does the exact same thing at the same lift and all depressions. Should I be looking at the chamber/ valve seat transition?
comp262
Re: flow testing
Postby Chad Speier » Tue Jan 03, 2017 9:52 pm
comp262 wrote:Hi Chad,
Do you have a set of flow balls?
Re: flow testing
Postby comp262 » Tue Jan 03, 2017 10:31 pm
Yes Chad, apart from the slight flow stall, the port behaves fairly well and the balls don't tell me much but I am not an expert using them. What should I be looking for in this situation please?
comp262
Re: flow testing
Postby Chad Speier » Tue Jan 03, 2017 10:39 pm
I would put it at the lift it acts up. Probe the port with a flow ball at 28". If the depression lowers, that is the problem area.
Re: flow testing
Postby comp262 » Wed Jan 04, 2017 4:15 pm
Thanks Chad,
I will give that a try next time and let you know how I go.
comp262
Re: flow testing
Postby Tony pierce » Fri Mar 31, 2017 10:17 pm
Hi Chad hope you can help me I have a problem with one port it flowes good up to .700/355 and then it starts going back down.750/330 I check my air speed with pilot tube at about 1/8" off ssr and walls floor and roof to get my reading 430/450 on ssr and 400/380/370 floor port sound good very little turbulence in port I have flags to check with and flow balls have a few spots were flow will pickup a few cfm 3 or4 and other spots lose cfm 5 or6 maybe I did something to ssr Iam not realizing thanks for letting me on your post I like doing this stuff hope to learn more about it some of its over my head but I like a challenge.
Tony pierce
Return to Flowbench Talk
Users browsing this forum: No registered users and 1 guest
cron
